How does the Lucky & Wild sit down arcade machine come apart?
JedahDoma
Wichita, Kansas
I may be purchasing a full size sit down Lucky & Wild machine from someone in town. Problem is I'm not sure if I can get it in my basement. This thing is bigger than I remember.
Does anyone know if or how this come apart? Is it able to be taken apart and broken down then reassembled?
I had the displeasure of taking one of these things apart for someone so I recall it well. I believe there are 4 bolts along the bottom sides that you have to undo, in addition look in the backside of the cabinet toward the foot pedals, there might be another waiting to be loosened as well.
The two parts I had to remove were a PITA, hopefully yours will slide apart easier than mine.
Good luck.
Good luck.
You think one of those taken apart would fit down a stair case that's about 35" wide?
The rear section with the seat, probably. The front section might be tight but there should be some specs on a flyer somewhere. Can you get measurements?
Yea the eBay seller just shot me some numbers. Said it's 72" tall, 34" wide, and 69" long. They also said once the seats came off it was about 24" shorter. I guess my only real worry is the 72" height. I may have to fit it in my van sideways or rent a truck.
