I've got a boatload of chips that I'm unsure they're fully functional.
What's the best (and most economical) way to tell if they're good?
For out of circuit chip testing I use my ABI chipmaster, it's been pretty good so far. I know that the some eprom programmers like the TL866 have chip testing functionality and might be your best bet. Some of the superpro ones do too.
Too many false positives.
RCT pro is all you need.![]()
Loose, out of circuitAre they on a board or loose?
I have one similar to this. Some it wont do. but works on most. For the price, you can't go wrong.
Get a known-working board that has those chips, and socket them so you can test others. I have one Asteroids board that is almost completely socketed, where I can test most of the chips I work with, if I have any doubts.
The best way to test any chip is in another working board, in the same location you expect to use it. That way you're testing it at speed, as it's used in an actual circuit.
The only thing you have to be careful of is cases where not all of a chip is used. Many chips are multiple copies of the same thing in one package, and not all of them may be used. You can look at the schematics to figure out if that's the case.
I use the same one Charlie shows, as well as the retro chip tester pro.
I got you mixed up with Overtime Arcade guy. Oops.Charlie is someone else, I'm Charles.![]()
