Well, Mod said in another post that they use different ICs. So if you know which IC each uses you should be able to tell the boards apart. Of course, I just plug the monitor into a cab and look at the display. If it is standard res it will sync (possible after adjustments), if it is med res it will have multiple overlaping images.
