How do you remove the tip of the Joystick?
ok, I'm not going to sell it...I just got it :p. Thanks for the offer :).
Can someone explain what sort of Voodoo holds the gimbal ball in place? The manual says to use a 3/16 punch to knock out the pin...umm, there's no pin in there. It's like the gimbal ball is magically stuck on the shaft :(.
Well, it was worth a try. Spin the shaft around until you see the rollpin. You need to punch it out, check this out:
http://www.basementarcade.com/arcade/4sale/gimbal/index.html
It doesn't show the rollpin but you can see where it goes.
Greg
That sorta looks like a Monroe stick. Is it? If so, the black ball will unscrew. Or you can pull the clip off the bottom...
