How do you remove a yoke?
tevans333
Bloomfield, Michigan
I've searched and come acorss a lot of threads about swapping yokes, but none about how to actually remove one. I am having trouble removing mine. It has the magnets and yoke all together on one plastic piece so they all have to come off together.
I am seeing two problems though:
First, what appears to be white two sided tape under the assemlbly. I think it is loose that I can wiggle the assembly off of it, but it there generally a good way to get it unstuck from the tape?
Second, the yoke is glued with tons of hard yellow goop to the foam wedges. The foam wedges are also all glued up to the tube. Can this be removed or am I screwed?
