How do you disassemble leaf switch button
supercharged
Portland, Oregon
I pulled the button of the panel by removing the large but. That is the easy part. How do you get the button out of the housing??
Depends on whether you have a snap-in or a clip-in. If it's a clip-in, just remove the clip on the bottom. if it's a snap in, then you need to pop it out. A hammer will work if you have something round and hollow that can support the lip but allow the center part to pop out. Otherwise you can hold it in your hand and slam the bottom down on a table pretty hard and it should pop out.
Or just buy new ones at $1-2 each.
Why do you want to take it apart? If it's sticky, just squirt it with Windex, actuate it about 50 times or so, wipe it dry, then use...
I just want to know it is clean on the inside as well. I'm kind of OCD like that. My games could be used in a doctors office. Literally!
