mystery_base
I use copper trace tape to repair those...
Here are a couple of pics of a Pac Jr. board I repaired.
Take a sharp knife and cut the bad trace. Peel it off the board if loose. If not loose use a soldering iron to heat it up to where it can easily be peeled off.
The trace is the same on the top & bottom so just wrap the tape around the board edge from top to bottom and solder it to the existing trace on the board.
RJ
Damn fine looking repair
