How do i make a 4600 screen wider (in verticle position)
I need to make the verticle width wider on a 4600 chassis...which pot do i use?
If mounted horizontally, look at Page 3. Section 3.0.
if mounted vertically, try the width coil which is mounted on the frame.
http://www.arcade-museum.com/manuals-monitors/WG K4600_Manual.pdf
If you had the monitor horizontal which dimension are you trying to increase?
If monitor was horizontal it would be the height im trying to adjust..up/down dimension.....its to narrow.
Use pot from Colorado and sit closer to the screen. Problem solved.![]()
