How do I adjust monitor brightness on Gyruss
learpilot2
HILTON HEAD ISLAND, South Carolina
I just got a gyruss. It works great, however, has some monitor burn in. I think it is due to the brightness of the screen. The screen in quite bright. I want to turn down the screen brightness, and I cannot find the monitor brightness adjustment. Anybody know where it is at???
Depends on your monitor.
There are 3 controls you will have to fine tune. First off, there is the screen control on the flyback. Odds are this will fix your problem. Second, you will want to fine tune the brightness and contrast pots on the back of the chassis. In most cases, if you turn all of the pots to exact center they will be right. Then you just dial in the flyback screen control and adjust the flyback focus knob.
You need to get the model number of your monitor chassis, then get a pdf manual for it online. There will be a diagram in the manual showing the locations of all the adjustment knobs.
