I'm trying to remove the screening from a Midway 25c insert and was wondering if anyone knew how to do so. Alcohol and Goo Gone don't do a darn thing.
why....?
If you need a clear piece of acrylic just cut one.
I've done it with lacquer thinner on a rag or paper towel. Wipe quickly and it will remove the silkscreening without hurting the plastic.
I have done this several times in the past with excellent results.
I might try that if no one else has an answer.
Hey Jr. Pac, Ken took the time to pop into your thread and answer you, you can rest assured that nobody else is going to have a better answer.
take the advice
You think the one's on my coin door are too far gone?
In fact, are these or the badges reproduced?
Thanks.
Darren Harris
Staten Island, New York.
here is the thread for the Midway plates:
http://forums.arcade-museum.com/showthread.php?t=244773&highlight=midway+plate
I vectorized the artwork myself. Btw - I'm a professional graphic designer so I know what I'm doing![]()
I don't have the time or money to make it absolutely perfect.
Thanks.
Darren Harris
