How can I put my change machine on "Freeplay"?
Shavenyak
Donor 2023
Sarasota, Florida
I would think this would be relatively easy. My manual doesn't say anything about it. Has anyone done this?
Not necessarily. It would depend on the make and model. These things were never designed nor intended for that function.
depends..
if you have a test vend button, wire up to that and use a push button switch to activate..
on my old rowe changer, the computer part was shot... my rowe also is old enough that it used to take 50 cent pieces...
so i wired the little door/solenoid that "spits the coins" so its open at all times.. I then wired 110vac to the hopper motor and the circuit is completed via a pushbutton switch mounted inside the frt door. THeres a coin retuen lever on mine bieng it used to take 50 cent pieces so i made the coin return lever acuate the switch. So now when i hold down the coin return lever, the hopper motor runs and she spits out tokens...
I would strongly reccomend the test vend button to external button method if you changer is in proper working order.
My way was done because my machine is just totally effed otherwise lol
