Horizontal Position
friedfish
Newark, California
I have a monitor that I have just put a new cap kit and flyback on the chassis and when I power up the monitor, the picture is not positioned horizontally centered. When I adjust the H-Pos on the remote board, I can get the picture centered horizontally but then it is curvy at the very top of the monitor. I can adjust the H-pos to get rid of the curviness at the top, but then the picture is not centered. It is either off to the left or to the right of center.
The width of the picture is also perfect. The picture on the monitor looks great other than this one issue. The same issue persists with another chassis when I connect it to the same tube. Anyone have any thoughts how to correct this issue? The monitor is 25" WGK7000 series.
After you adjust your H-Pos pot, have you tried adjusting your horiz hold or 50/60 hz pot? There is also a horizontal position jumper located back by the yoke connector....
