Horizontal Position knob
Moonman
Georgia
I got the other two games working that flaked out on me Friday night but the one with monitor issues is going to have a part. The monitor in the Max Force I bought is beautiful but it would take a few minuets for the Horizontal to settle down and then it was fine. I guess it finally gave up the ghost cause now it wont settle down on its own and if you adjust it it doesn't stay correct. It gets unstable and lets loose into a blur.
This monitor only has the remote adjustment pots. Is there any easy way to check and see if I just need to replace the cable(controller) or if its on the main monitor board. Also where would be the best place to get another control panel/cable. Anybody know the answer??
I believe this is the number you are asking for WG 155 09 39
There is however one other number WG EC 088x0407-001 ( I think thats the tube type though) If neither is what I should be looking at I might need to take a picture cause I don't see any other IDs
Make and model of the monitor is "Required".
LOLs I figured. I'll take some pictures. Thanks BTW how hard is it for a company to just stamp something they make with a tag or number that says "id" on it....
Nope, not even close. Take pics
As I was taking the pictures I caught the number on the actual remote control panel and it looked familiar , sure enough the monitor in an unused cabinet I have was the same(Except it had a different letter on the end of its numbers). I figured it was worth a try and yep swapping them out fixed the problem. Now of course I need to buy a replacement for the other monitor so it will still work. Who carries those type cable/controllers ?
