Horizontal Pos Pin on a K7000 Wells Gardens
Artcade
Hello folks,
I was playing around the Horizontal Pos on my Dragon's Lair 2 when I realised that my image was a lot larger than the regular 25" screen frame. I got a pretty good fit with the Width coil but I have not seen any major changes with the Horiz Pos pin.
It was originally on the very right.
On the same screen but from my X-men cab, the pin was set in the middle.
Can somebdy explain me the purpose of the Pin setting and what setting I should select?
Thanks !
The jumper is to be used at your discretion. Sometimes it improves your ability to adjust/fine tune the image if you place the jumper left - middle - right. Its usually very slight in change.
