Horizontal Combing on Tovis MTG-2901CN (Outrun)
qseventeen
Iowa
Hello,
I'm hoping someone has seen this issue before. I'm getting what I can only describe as horizontal combing on a Tovis MTG-2901CN hooked up to an Outrun PCB. I was hoping a cap kit would fix it, but it appears exactly the same. Any ideas?
Thanks,
Ryan
If you have a TPG or another PCB, I would run a test pattern into the monitor to see if it does the same thing. I would also check the Outrun PCB on a working monitor to make sure its video is good.
Hooked up a different game to the monitor and it worked fine. Turns out my Outrun cab had its connector to monitor hooked up incorrectly. The ground and sync wires specifically. Got it working now. Thanks.
