hooking up speaker questions
Fatality83
manchester, Pennsylvania
I have a Rowe Eagle wallbox. The manual goes into serious detail about if you have this type of speaker hook it up this way and so on. I have two Polk audio tower speakers with a built in tweeter, midrange and built in sub. I believe it says 71 watts each on the back so I know I am fine as the total of the speakers is less than the jukes total amp output 250 watts. My question is, in the manual it says 8 ohms 4 ohms or 72 or something like that. How do I know what ohm my speaker is? right now I have one each hooked up to the 8 ohms 32 watt output as that is as high as my manual goes. It does not go above 32 watts. Just wondering what connections I should make for these speakers to get the best sound. Thanks.
