Hooking a Monitor Back Up - RCA Tube, Hantarex Polo Replacement Chassis
arcadegarage
Pennsylvania
Hi guys,
I have a Tekken 2 MAME project that I am trying to hook the monitor back up to. Some wires were cut awhile ago and the project never got finished. I'm not sure which wires go where and don't want to blow the yoke so I'm requesting your help to rehook everything up properly.
It's a 25" RCA tube I believe (see picture) and was a Hantarex Polo chassis. A new monitor chassis was ordered from 8liners.com...looks like a Chinese chassis but not sure. The monitor was fine until the Hantarex chassis blew and that familiar burning smell came through. I couldn't find another chassis anywhere so I contacted 8liners.com. The degaussing coil should be on the monitor as I believe thats what the one 2-prong connector is.
I'll upload the pictures of the current monitor and all the parts to the new chassis. Hopefully you guys can shed some light on this.
Thanks in advance!
Picture 2 is the yoke wires. Not sure where you'll get the molex that connects to the Polo chassis. Not sure which set are for horizontal or vertical, nor what order they go on the connector. You can measure the wires, and the larger ohm set should be the vertical. Then look at a Polo schematic for the order to connect them.
Picture 3 is the degauss connector. It plugs right into the chassis.
Picture 4/5 is the video input connector. You should be able to get a regular video molex/pins pretty easily to put on there...
Other pics
and I think the other connectors that came with the chassis should be fine to use for some of this for the yoke? Did you have a look at the other pics? Problem with the polo schematic is the it doesn't show the wiring. Since it's no longer a polo chassis and a RCA tube...is this no long a hantarex polo and do I try to find a schematic for the RCA tube?
For the yoke wires, I see red, yellow, orange, and brown. The red and yellow match up to the red and yellow on the new connector...just not sure about the orange and brown.
