homemade tempest help!
partygt
California
i got a cab from a friend that made this came out pretty nice but.....quickly found getting all the parts not cost effective so.... i am wondering if i could take a multi pcb that has tempest on it and get it to work with a spinner and hook up a lcd? like a poor mans tempest! i also need a marquee for it wood and all.
Two totally different spinners. It would not be fun to play Tempest with an Arkanoid spinner.
It looks like it has a spinner. I think he's just asking if anyone has used a spinner controller on a multi pbc. How it functions I would assume.
I've thought about turning my empty Arkanoid cab in to a multi but have never tried a spinner on a multi board, sorry.
I would go with a Raspberry Pi and run Retropie. It has all the Tempest games, and recognizes an aftermarket spinner as a mouse. It will look fine after some tweaking on an LCD.
I see no reason why you could not wire the the two signal outputs to Player 1 L and R inputs on your JAMMA harness. You would need to feed your spinner whatever voltage it needs from your power supply (probably +5V). I've done this with a trackball and a spinner should be the same as one axis of a trackball.
Anyone try spinner on multi pcb for tempest or arkanoid?
yeah i needed to order a cheap adaptor harness to work with 412 in 1
it handles both player 1 and 2 with a single plug.
Also, the lcd is not as bright as crt so i had to switch the tinted glass out with clear plexi.
also (before anybody ask) the streaking in the paint is the clearcoat. i rolled the white on and added alittle extra protection with some spray clear
until it gets side art...
The button placement would make 8lb 5oz baby Jesus cry!
does anyone know what the 4 wires are going into the tempest spinner and which color is which?
