Tornadoboy
I like the kitty litter idea someone mentioned earlier, I think I'm going to pic some up later, dump a ton of it inside and let it sit for a few days.
Then you have diesel fumes building up over time in an enclosed space with HOT electronic circuitry, that's always fun! Could the diesel that soaked into the wood of the cab possibly ignite if it got too hot? Then there's that sweet diesel smell that'll never go away. It'll be a total adrenaline rush every time you play!
Ok I just dump a bunch of kitty litter in it, I'll let it sit and change it a few times over the next week. There's also some Fabreeze-type of stuff I once used in my car that worked great, I'll have to try that afterwards.
I have a walk out basement and for some stupid reason they piped it out the back, which comes out about 10 feet off the ground, and above a snow bank right now which makes using a ladder a pain.
WTF were they thinking? The oil delivery man must hate you.
Heat gun? You've got to be kidding... It's the fumes that are the problem with flashing over... and you'll have an orange hot heating element... EEEK!
Diesel fuel is oily and gets into everything.
To get the kitty litter to work you may have to crush it and rub it onto the wood the same way you crush the litter under your shoe and rub it onto concrete to pull oil stains.
Once you clean it the best you can use Killz to cover it. That paint is supposed to cover over oily stains. If you don't like the white then paint it black after the Killz dries.
Moving it to the other side and getting a vertical tank to free up floor space is on my to-do list, believe me.
Vertical tank? I didn't know such things existed! I have a 275 gallon horizontal version. Do you think they make a vector tank?![]()
It's just taller than it is wide, I'm not sure if my basement's ceiling is high enough but I plan to check into it.
I think vector version came out about the same time Polybius did.
