Steelhorse
The flipper on the left side seems to get hung up when you use it therefore resulting in a weak hit. I lifted up the PF and grabbed the flipper and pulled it back and forth and it's hung up some what, so I replaced coil sleeve and went to tighten down the allen bolts and now the flipper has alot of hang up, seems like the plunger link that goes through the coil/coil sleeve theres some hang-up. I treid putting new coil stops in and well it seems there the wrong ones although there the right part number the stop is smaller then the one thats on there. The only time it goes smooth is when the allen bolts are extremly loose, also there alot of play in the coil itself you can grab and move it side side with significant amount of travel. The othe flipper is nice and smooth. I'am new tothis so all help is appreciated. Thanks! Jeff
