High speed help
NEGAMES
Red cloud, Nebraska
Hi I bought a high speed tonight. was wondering if someone could give me a close up shoot of the clear bottom far right plugs on the power supply? Also can someone tell me where to check for the correct voltages on the power supply and what they should be. Who ever had this before me soldered wires directly to the power supply but never hooked up the wires. cut the wires from the origanal plug and they are laying loose so not real sure where they belong. Any help would be great.
thanks
okay got the wiring figured out on the power supply. How ever now the red led light on the main board is flashing 493 and the three stays on. the game will not start a game. When you coin it up the red light on top flashes and it acts like the balls are stuck because all the pop bumbers energize. the ball are setting in the kick out lane however but everthing is dead past that point. In test mode everthing appears to work however. Any ideas?
