gwarble
wow this looks cool, thanks for sharing!
i will test as well but probably not til the new year
I am thinking about getting one of the 8080 fusion boards as a backup. Would you be willing to authorize inclusion of the Seamiss ROM on that board?If anyone else wants to kick the tires before I call it done, asm and ROMs are up at:
GitHub - mcspaeth/seawolf_z80 at seawolf_2024
Midway Sea Wolf commented disassembly (as z80). Contribute to mcspaeth/seawolf_z80 development by creating an account on GitHub.github.com
@HudsonArcadeI am thinking about getting one of the 8080 fusion boards as a backup. Would you be willing to authorize inclusion of the Seamiss ROM on that board?
Thanks! I'll give them a look.booting to verticle lines means it is not loading roms. look for dirty sockets or bad solder joints
@HudsonArcade
Bump
Unfortunately my machine is now booting to vertical lines. Hopefully I can fix this but having a reliable backup that could play Seamiss would be extremely comforting.
In that case I'd better get to figuring out how to bulletproof my board.I'd prefer that parasite not profit from my work.
Wow! Looks like I know how to hide things from run-of-the-mill Windows users. Just put it in a zip file in an unnamed directory.I just downloaded it and the file contains 6 bins. two of which are combined into g and h for you for the 2716. did you use 7 zip to open the 8kb zip file?
the zip file looks empty if you use windows built in zip but 7 zip opens it right up
Looks like there are 3 branches on github. Guess I'll try the other two.Maybe it's because I haven't had my coffee yet, but I have I'm beginning to doubt my technical ability to pursue this hobby much further... lol I have checked this 3 times and the files in the zip file are identical to the original ROMs.
Also, I can't just paste images into the thread anymore. I need to save them and add them using the toolbar. Is this another strike against WIndows users?![]()
That's test mode... flip the switch and you should be fine.Looking forward to playing this, but the zip file on github appears to be empty. I did download the bin and split into two files for 2716s but must have done something wrong unless this is some new form or retro copy-protection.
I'll look at the ROM contents again, but thought I'd post this in case it's something obvious I missed.
You can only paste images when the editor is not in BBcode mode. Press this button and try again:
#RTFMThat's test mode... flip the switch and you should be fine.
