Help with Williams Base Hit
get2thechapaa
North Carolina
When a coin in inserted, it only goes to the 2 player selection. It will not play "single Player". It works fine with two players but for some reason it will not select single player mode.
I have a schematic but not sure how to follow it to solve the issue.
Help?
Williams Base Hit 68.
You can play one or two player.
This game has the option to select single or two player mode. I am pretty sure it has something to do with the number of coins inserted. If two coins are added, it steps some relay to select "two can play".
Interesting.
I was reading the flyer which just says "two player".
Which could be interpreted either way one or two player.
http://www.ipdb.org/showpic.pl?id=2900&picno=11532
The reason I thought its a two player only game is first comment on the rating section of internet pinball database the first review suggests its two player only.
http://www.ipdb.org/machine.cgi?id=2900
The most recent comment in the rating section says "another two-player game that may as well had been a single-player".
