davek
I've got a WG4600 that started flickering to a primarily green picture, now it seems to stay green all the time.
I tried adjusting the RGB pots on the neckboard, and red has no effect, blue has a little effect. So I figured the red C2068 transistor was the problem, replaced it, and still have the same green picture.
I thought maybe the pot was bad, or solder crack. I checked them all out with my multimeter, and they measured fine.
Trying to rule out a problem with the color card, I removed it completely, and with no input signal, still have a green screen...although....after a minute it flickered to white for a minute, then back to green. It did this randomly, primarily staying green. I tried taping the neckboard and pots again thinking cold solder joint, and just around a couple other places, and nothing seemed to set off the flickering...it would just randomly jump to white, and but stay green a majority of the time.
Any recommendations?
