help with wei-ya 2620h monitor chassis
darrenz
New York
i just put this universal chassis in. and i have a green tint to screen with vertical lines. cant seem to make go away. any help would be great thanks
update...
ok this is a cocktail table that monitor tips out to service. when tipped out has the green tint and lines, but as i tip back in most of green turns to blue????................now i went to mess with again and turned on while tipped in and screen greenish,tip out and starts turning to red???? this is the 2002 ms.pac/galaga there are magnets in various place wrapped around harnesses. does this have anything to do with?
Don't judge the color variations based on opening and closing it. You are causing a gaussing effect. CRT's are meant to be set and adjusted and left alone.
Open it up enough to adjust your colors, close it and leave the machine OFF for a bit and then turn it back on and see what it looks like.
Is that the best the image gets in your pic ?
(seems dark and missing colors)
problem is that there is no way to get at adjusments when tipped down. heres another pic. one thing i did notice.... you know how when you shut off a tv youll see a tiny green dot? when this shuts down you see red,green,blue all together go into a dot if that tells ya anything also this green seems like a constant glow, i was adjusting brightness and could see it was adjusting the picture but not the glow of green.cant see great in the pic but the whole screen is green.it seems like something is producing this...the green gain adjusts the color of the actual game picture but not the glow of the screen. someone please help
green screen was bad tube
just squeezed a nice 2006 20in sanyo flat tv tube into my game and the green is gone!!!!!! if you encounter this same prob dont be confused by the vert lines thinking its a brightness issue. in my case brightness,color etc did adjust the look of the characters but not the constant green glow. yes the lines appeared because the green glow was so bright but none of you adjustents will take away because prob was at tube.also if you turn down both brightness and green doesnt go away i would say tube. i was scared a sec after putting 20in in cause had no pic at all cause brightnesses were all the way down, yet on old monitor still saw the green all the way down. good luck
