Help with Sony PVM sync issues
tparis
Donor 5 years: 2015, 2017, 2019, 2022, 2025
San Diego, California
HAPPY 4th!!!!!
Setting up a test bench to fix a Monaco GP.
Another KLOV member mailed me some BNC adaptors but until they get here another friend loaned me his.
Out of the game I have Red, Green, Blue, and 2 sync wires.
On the front of the monitor I pressed the EXT SYNC, LINE RGB, and H/V DELAY settings
Unfortunately I am unable to get the game to sync properly.
Based on these images can someone help me
get this working?
Thanks!
Stupid Question:
So would I ground from the switching power supply to the EXT SYNC?
If so does it matter if the ground is in the neg or positive input of the BNC adaptor?
Thanks!
Stupid Question:
Thanks!
You need to supply video ground to the BNC connector(s). Connect the video GND from your video source to one of the minus (-) terminals and then daisy chain that to the other three if desired/needed.
Ok so here is my video out.
I have rgb and sync. On the bnc adaptor I have attached a ground from the switching power supply. Obviously I'm miss-understanding cause the image is the same.
So... you have yours grounded but tell others not to ground theirs cause it's not needed...makes sense.
Do you even PVM bro... yes you need ground but only to one BNC connector since they are internally grounded!
lol, do you even electricity? Nothing works without a ground reference.
OP, based on what I see in the schematic, MGP outputs composite sync, so one of the yellow / gray wires is sync and the other is ground. If I was a betting man, I'd say gray is ground. Disconnect ground from the power supply, hook yellow into the + terminal of your sync balun and gray into the - terminal.
I have no idea if MGP outputs positive or negative sync, so you might need a sync inverter to drive the PVM, which only does negative sync. The buttons can be somewhat confusing. If you have a known good source of RGBS video, you can hook that up, set the PVM controls until you get a good picture, then connect MGP. That way, you know the issue isn't with the settings, and can concentrate on getting the adapter right.
What he said and why are there two wires connecting to the external sync?
I use a BNC to VGA cable and that same Mike's adapter. It's a nice clean looking setup. Glad you got it working.
That is not a picture of a working setup. Your horizontal sync is still not working correctly, which is causing the jagged areas on the side and possibly messing with the clamping values.
