Ok this is really embarrassing. I want to paint my pacman control panel and put a new cpo on it but i can't get the fricking joystick off!!! I googles it and did a search on here. Is there a trick to this? thx
There is a c-clip holding the joystick handle on from the bottom of the joystick. It can be removed with a flat tip screwdriver, just push it off.
Twist the red ball until it breaks free from the centering grommet. Once you have the stick out, lightly sand the shaft before putting it back in. Doesn't hurt to spray it down with WD-40 either. Just don't take a hammer and beat that sucker out, because you will mushroom the end of the shaft.
