Help with my buck rogers pinball
brad5793
FARMINGTON HILLS, Michigan
Hi guys hope someone can help The game will not start up when I push the credit button but then it will sit for a little bit and will start up but will not kick out the ball. Everything seems to work if you Manually put the ball on the plunger lane then you can play the game oh and also sound only works every here and there but when i push test on the sound board it is fine.
