TormundGiantbutt
- Joined
- Jun 10, 2024
- Messages
- 2
- Reaction score
- 0
I recently acquired an old Kramer Krane and everything works except the claw doesn't drop.
I've looked over all the other threads I could find, and have gone through the troubleshooting listed below, but still can't get it to go down.
- Checked to make sure the string is routed correctly/wound the right way
- Checked the claw limit switches (one switch needed it's lever bent a little so it wasn't always engaged, but continuity test on both was fine)
- Can manually pull the claw down and it will unwind/go down, then the motor will retract it back up properly, but it just won't go down on it's own.
