hey guys,
I got this K7000 popping fuses so I got a Bob Roberts K7000 kit and replaced all the caps, Flyback, and the Hot. Still popping fuse right away. I suspect the Hot. first of all, the hot that comes in the Bob Roberts Kit has legs that are too short. I had to drill a new hole in the heatsink so I could lower the new hot enough to solder the legs. I didn't think that would be an issue but maybe I'm wrong and that's my problem?
I checked the hot with a dmm (Set the dmm to 200k) and I get a reading of 1.4
does that mean a low reading and shorted? or should I set the dmm to 20k?
any help much appreciated, I was gonna send it out for repair, then things got crazy at work and now I got a little free time and I think I can fix it with the help from you guys.
