help with installing 60 in 1 pcb...what is SW3?
Kung-Fu Master
Permanently Banned
Murrieta, California
i have no test switch..so i put the pcb dip switch 4 on....
it allows me to use the start button P1 AND P2 as the toggle,.to go through the menus...
player one is SW1
player two is SW2
.....but at the end of setup...on the last page, after volume check...it goes to this page where you can push the joystick up or down..left and right...
but its saying press SW3!
to advance...and finish this final stage...what do i do?...i have no SW3....
im lost. i turn it off and it just starts the the whole thing over. i cant get the pcb ready to play...help?
Been awhile since I messed with one, but I thought "SW3" was the dipswitch "bank" itself.
So it is telling you to turn dipswitch 4 back off.(the one you turned on to start the test menu)
But then again, I could be totally wrong.
Hopefully you pressed Player 1 Start on the volume screen to save your changes before you did...
