jonathan1138
My Spy hunter has a PCB related White Bar at the bottom of the monitor, about an inch - inch and half thick. This white bar is not going away - its part of the PCB - if i use Horiz Freq that white line wraps around to top of screen.
I've managed to stretch Horizontal (the monitor is mounted vertically, so horiz is the top / bottom) to the far edge of the screen successfully, but as noted the white bar is still there.
For my next trick, i want to stretch out the pic further - by an inch or so - to hide that white line once and for all!
I ordered this kit:
http://therealbobroberts.net/width.html
Which is the Horizontal Cap kit. On my G07, C515 is currently a value of 534k.
Before i start to go mad experimenting, can someone here please suggest the best values to start off with to stretch the image a little more and also explain what "HEAVIER" is? The kit includes the following:
* Width Cap Kit
* F104K 250V
* F104JK 250V (Heavier)
* F224K 250V
* F224K 630V
* F334K 250V
* F.47K 250V (F474K)
* F.47JK 250V (Heavier)
* F474K 630V
(I am guessing add a 104k to the existing 534k and step up from there based on what i see - is this ok?)
Thanks.
I ordered this kit:
* Width Cap Kit
* F104K 250V
* F224K 250V
* F224K 630V
* F334K 250V
* F474K 630V
Thanks.
