jimkirk
I just replaced the outlet on the DK for the monitor and marquee with one off another DK power brick and measured the voltage and it is 109v instead of 100v.
It fluctuates between 109.1v &109.3v.
Is this too high for a Sanyo monitor.
The other lines coming out go to a switching power supply and read 105v-105.1v.
I am confused because,according to the manual,both sets of wires comming from the iso are supposed to be 100v.
I had a Tovis monitor hooked up to the same wires,that the outlet is on,and it worked fine.
It runs off 100v-120v though.
