ManNamedJed
- Joined
- Feb 10, 2003
- Messages
- 1,439
- Reaction score
- 50
So my Cyclone has an intermittent reset problem. I have replaced the Bridge Rectifier, Voltage Regulator, the large main cap on the power board, and the 2 smaller caps on the power board. Each time, I thought I'd fixed the problem, but then would eventually get some resets.
What else could cause this? I've checked the voltage at the outlet and its fine. I've looked for broken diodes and haven't found any.
Other suggestions on what could be causing this? Thank you!
