Help with blue screen g07
jerryme
Ypsilanti, Michigan
Hello, I need help with a blue screen issue, the monitor played fine then all of a sudden I turned it on and there was and overpowering blue to the screen, but it could still play, so I pulled the monitor removed the chasis, replaced x106 when it tested bad, then I put it back in and it played fine. Then I fired it up this morning and the screen was blue again, there are these small jumpers on the underside of tthe main board they look like some kind of diode with a small piece of tubing around it that passes right between the solder for the x106 - also when I pulled the x106 the 1st time there was a wierd brown rubbery melt right there on the solder side of the board. What would make the transistor blow? well hopefully someone can help me out, I am going to pull it again later today. Peace Bart
