I recently got a non working frogger cocktail for $75 that is in great condition minus a few small parts to make it whole. when I got it home before trying to turn it on for the first time (did not even try before I bought it) I looked it over and noticed one cable was not pushed in. I pushed that in and turned it on, it worked fine. here is the problem I can not seem to get it in focus, I tried several things such as changing the brightness and focus/screen and eventually got it better but its dim if you make it brighter with the brightness nob it looses its focus and the focus is turned up as far as it will go. I also tried to trim and re soldered the focus wire with no avail. I do think it was recently capped. I know its likely to be the flyback or the tube, but wanted to see what else I could try before i try to find a rejuvenator (also thought about making a rejuvenator) or flyback. I think the monitor is a nanao mc 2000s. thank you for your help.
