help with a k7901
paul400
Hixson, Tennessee
ok, I rebuilt this chassis caps and flyback,fired it up and looked good. turned down the brightness alittle and I heard kinda of sizzling sound looked at the screen at it had lots of static and was blacking out a bit. WhenI turn the brightness back up it stops but its a bit to bright. i belive it is coming from the neck board also focus can make it start to sizzle. i reflowed everthing on the neckboard with no luck. I think it might be P201 but not sure. I wiggled it and it got better but not totally. any help would be great.
Ok. Swapped out the neckboard and fixed the issue. Has anyone heard of this problem and how to fix it since my spare chassis is down now.
I'd check/clean and/or replace any of the pots on the neckboard and check/resolder all solder points and verify continuity on the traces to be sure something hasn't broken or come loose.
