Help with a 60 in 1 -- backwards controls
kelleyphd
Pennsylvania
Hi All,
I just put a new 60 in 1 in a Quarterback cabinet. All of the diagnostics work fine. I coin it up and select a game where the joystick works fine. Then when the game comes on the controls are messed up. For instance with DK, mario just goes right. If I push the stick right, he goes left, leave the stick alone and he goes right again. Frogger starts and he immediately goes down and then I can't get it to go any direction. Other games do similar things. The puzzling thing is that I went to the setup diagnostics page and tested the stick and all buttons - everything is correct.
I have an 8-way stick in there right now.
Any ideas.
Daniel
sounds like a board issue if you went to the test menu screen and everything checked out with the movements.
Figured it out. I had some other wiring from the old game that was grounding the stick causing it to go right all the time. Could not even see the wire. Anyway, it works fine now. Thanks.
Daniel
