Help wiring
SilentScope360
Olympia, Washington
Could use some help. I'm trying to wire a cab
Can someone explane these wire colors to me. The whites/blue/Brown and the smaller twisted wires?
Where do the go?
What a task this is turning in to. I know red monitor,green. There Power wires not jamma.
For the moment just a 60 in 1. I'm trying to wire up a gutted cab basically to fix and test monitors. But i am trying to wire in interlock and i think thats what keep throwing me.
Green is usually Field Ground. It goes to all the metal on the cab.
Red is usually 5v
Orange is usually 12v
Blue -5v
Top wires look like speaker wires?
But we need a lot more info.
The white wires Hot/neutral, At the top of the harness It piggy backs and has connector that connects to marquee light. I guessing the other end goes to on off switch. so then what dose the blue and brown tie into??
Top of harness, Do i connect the Blue and brown wires i have marked interlock. To the interlock and the run another set of wires between on/off and interlock?
Thanx again for no help at all. how hoard was it to say yeah that will work.
well level up for me!!!! it works Got power brick and harness built.
Wow, won't get much help that way.
Your A/C wiring above does NOT look correct. (We can't see all of it. If it follows below, you connect the 4 wires to the interlock in your picture.)
Power from your power cord should go to a fuse (typically 5 amp) than go to the interlock. Next it should go to the switch. Lastly, it should go to the line filter (the silver box with ground). Marquee light doesn't have to go through the line filter, but often does.
After the line filter should be the D/C power supply and Isolation Transformer which leads to the Monitor. Isolation Transformer, depending on the monitor may not be needed and could be skipped.
http://www.therealbobroberts.net/acwiring.html
This page will help, but doesn't include an interlock. The interlock could chain from the switch.
