help wiring 26" Nanao monitor into Midway Blitz cab, from Virtua Cop2
Before I go ruining a good 26" Nanao...
I'm upgrading the monitor in my Midway Sportstation to a Medium Res monitor. I pulled a 26" Nanao out of my Sega Virtua Cop2 and installed it into my Blitz/Sportstation cabinet. I'm attempting to wire it to the Midway cab, but I do not have a schematic for the Nanao, and I did not take note of the model # before it was installed.
the 3 wires from my game's power supply are:
FG (Green wire with yellow stripe)
AC/N (purple wire with yellow stripe)
AC/L (purple wire)
On the monitor board there is "AC in" connector with a black wire and a black wire with white stripe. I assume FG is Ground which ends up screwed to monitor Chassis. I need to know which of the black wires is AC/N or AC/L. There is also a pair of Red wires connected to the monitor board. They were used inside Virtua Cop2, not sure if they are used in the Midway cabinet...
Any thoughts how to make this work? or any links to a Nanao wiring diagram??
AC/L (purple wire)
