- Joined
- May 2, 2011
- Messages
- 264
- Reaction score
- 25
I bought a cab with an old Playstation in it and ripped out the funky harness for the PS and I am wiring it up JAMMA. I wanted to keep the two 8ohm speakers and Coustic 100A amp setup but I am having some questions on the set up that I need help with.
On the back of the AMP there 6 wires- 12V & Ground, then 4 wires in the "LOz Input" which are Grey(R+), Green(L+), Green/Black(L-) & Grey/Black(R-). I was going to wire the 12V and Ground into my PS. The 4 wires for the LOz Input were already wired into a small board. There were 4 smaller speaker wires that I assumed I run back to my Jamma harness - (Question#1- Since I only have 2 sets of Speaker wires for the Jamma harness and I have 4 wires, Can I double them up and connect 2 wires to the one coming out of the harness?)
Question#2- if you look at the pictures you can see that there are 2 volume control buttons that are drilled through the marquis. These had a red/Blk RCI input that ran back to the PS. How can I wire this up to use these volume controls? or is that possible?
The pictrures show the front of the Amp set up and the rear set up. This was just have it was when I opened it up.
Thanks!
Thanks!
