midcoastsurf
Help: Vision Pro KT-2938 - not turning on (worked fine a few days ago)
Hello,
I have a Vision Pro Model #KT-2938 monitor. This is in my PGA Tour Championship Golf 3 game. The monitor is plugged into the computer via a VGA adapter and the power is supplied by a 3-prong plug that plugs into a powerstrip on the bottom of the cabinet. The monitor was working fine with no issues. I turned the game on last night and the monitor did not come on. I tried different plugs on the powerstrip and even plugged it into the extension cord directly without any change. I removed the VGA plug from the computer, hoping to see a "no signal" on the monitor, but the monitor remained black. There is usually no glow in the neck tube, so hard for me to tell when the monitor is actually working properly...other than an image being on the screen. I measured the voltage at the plug going into the monitor board and it read between 119-120 vAC. I also pulled out the little fuse right behind the power plug on the monitor and it checked out OK on the DMM. The monitor should power up just by being plugged in, correct?
Any ideas on where I should look next?
Hello,
