I just got a working Asteroids Deluxe board after a cap blew on the original one (I'll try to repair the original one at some point). I want to make sure that the power supply and regulator board are good before plugging the new one in. Any recommended testing procedures? I can see on the schematic which wires are what voltage etc. I'm curious where you guys find is easiest to do the testing. Are there test points on the power supply itself? Do you test at the cable that is plugged into the main pcb?
Also, is the power supply identical between all Atari vector machines so that info that I find on the other ones apply?
Thanks for any help!
Gary
Gary
