McCHitman
Help; Switching Power Supply reading higher than it should
I'm currently trying to get a Neo Geo MVS cabinet working. It was completely gutted and I'm following a diagram on the Hardmvs site for the wiring.
http://www.hardmvs.com/html/powerBoard2.htm
I have everything hooked up and I'm checking the connections with at Multimeter and none of the numbers on the Power Supply read correctly. They are close but not exact, the +5 is at 7, the +12 is at 19 and the -5 just shows -0. I have it adjusted as low as it will go and was wondering if I should get a new Switching power supply or will this be ok without any problems to my monitor or board.
