I can't seem to figure out how to remove the front glass Bezel from my machine. I bought a new one and went to install it but i am having some trouble.
pretty sure it's a lot like a nintendo bezel where you apply a little pressure and slide the bezel upwards until you can lean it enough at an angle forward to slide it out.
Ok, If I recall, the last time i removed mine, I had to get a suction cup from a window hanging piece of art, stick the cup on the bezel and lift straight up out of the track at the bottom and then it pulls out. The suction cup really helped. I couldnt get mine out without it.
there are 2 metal strips in my cab that are accessed from the back door.I have to pull them back in order to remove bezel . If not pulled back the bezel just moves up and down .
Does anyone have pictures of how this setup works? I had to replace the top board on my Space Invaders Deluxe. I am trying to figure out how exactly these 2 metal strips hold the bezel in. They end short of the bezel inside. I would like to get this back to original. I am pretty sure that I am missing something somewhere....
