I am almost finished restoring my coin door on my Bosconian and ran into an issue trying to solder the wires back to the connectors. The wire will not wick the solder even with flux. The solder just rolls off of it and I put some pretty good heat on the wire. When looking at the wire I was thinking that it was just oxidized and cut it back a bit more but it looks the same. Now I'm thinking it something like aluminum. Anyone got advice for soldering these? I can put quick disconnects on a few but can't on a button and a switch. Thanks!
