Help removing adhesive from aluminum
cnlmoore
Donor 2023
I've got an old aluminum tool case that will soon hold my jamma test rig. It had some pieces glued in place that I removed, but there is this hard, yellowed adhesive that I just can't easily remove. I don't want to use a heavy grit sandpaper if possible. Tried thinner, acetone, xytol, and a chisel. Have been using the blast cab but the stuff is really resistant. Any ideas?
They make a special adhesive remover they sell in the stripper aisle
at Home Depot .. works wonders. Removes CP adhesive residue like butter.
I forget the name.
novus 2, goo gone would not even phase this stuff. xylol did nothing I already tried. I decided to coat it with citristrip and let it soak overnight, I then used a scrubby pad and some elbow grease and most of it came off. I also used a metal putty knife to remove some. After cleaning it off, there was actually some left in the creases that I was able to sand blast away. Sheesh. Stuff did not want to leave. Hopefully I can spray some primer tomorrow and start the restore/build.
