Mrhide
I used the power cord from a u-3000 ( on the left below ) on a D9200 ( the right below )
As you can see, the ground is on the bottom for the u-3000 and the middle for the D9200 ! why this is not standard is weird but I guess I should have checked prior to power on.
it went "pjjjjttt" and turned off ... and won't power back on.
Anyone smarter than me can't point me to what could now be the issue? (schematics here) what did I break? (it ain't the fuse)
edit: in effect I put 120volt to all ground points! did I just fried everything?!
thank you
thank you
