help pls- Sorcerer volume gets REALLY loud off and on
vintagegamer
Donor 2024
Bear, Delaware
I've had my Sorcerer pin for about 5 years now with no problems. In the past year or so, if I leave it on for a while and go do something else, sometimes the volume will blast out during attract mode and scare the living sh*t out of anyone near the machine at that time. If I turn the game off and then back on, it stops having the problem.
Does it sound like a volume pot is starting to go? Or is it something else?
Two things you need to do:
Check the solder joints on the sound board, particularly the connectors to the volume control and speaker.
The volume control is dirty internally and needs to be sprayed out with volume control cleaner (usually, this is the problem).
I will check that out Ken, thank you very much!
