help on series 2 capt.fantastic
powermeup
WARNING: Proceed with caution. Many members monies
santa ana, California
lights up playfield,no score and it wont credit up,powersupply? any body know where to find these?
On the home models, the power supply board likes to burn up connectors and diodes. Be sure to check those.
If that all checks out and the voltages coming out of it are right on the money, then the CPU board has problems. Good luck trying to find parts for the CPU board.
Marco Specialties sells the service manual for the Bally Home Pinballs which covers all the models they made.
thanks ken. the power supply has little red buttons on the back(5) .the last 2 on the right dont seem to be working? there are 3 boards on the game and the board behind the backglass has 1 bulb on. should i check???
That's the power transformer module.
Slide the playfield glass off.
Raise the playfield.
Power supply circuit board should be attached to the sidewall of the cabinet.
Examine it closely for burnt connectors and also look at the female parts of the hardness connectors that plug into the board.
Get out the multimeter and test the diodes on that power supply board.
